Water got into my go pro while still on.
My battery lid fell off and ocean salt water got into my go pro while still on.
Это хороший вопрос?
Это хороший вопрос?
Hi @edwinnyagah
The impurities in the saltwater causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your camera and then remove the battery as soon as possible from the camera to minimize any further damage.
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a teardown video that may help
If this process seems too daunting, take your camera to a reputable, professional camera repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 18
За последние 30 дней: 93
За всё время: 897
