I cannot get the tv or the red lt to turn on at all
I replaced power board and main board, clicking stopped but no red lt at all. fuse is good, voltage is 12.86 at each of the inward pins on the black cable connected to power board side, the two on the end are both ground. I cannot get the tv or the red lt to turn on at all no sound no picture, two new boards. I have watched all the videos did all the unplug, press button tricks. I'm a master electrician, so i know about power, I'm not a tv repair man. If I unplug the ribbon cable going from top of power board to top of main board, in either direction the white backlights come on. power is getting to the tv, but not coming back out is a dumb guess, stone dead. i really need help. 2000 for the tv, it lasted 3 yrs. i know its something easy, i dont want to get another tv unless it is just bad somehow. 1st and 2nd pics are original power boards both power boards are identical. 3rd pic is the new power, 4th is th old main, note QN75Q60R, 5th is transceiver, 6th is old main bd. QN75Q60R. 7th back of tv, 8th new main board, same model number BN94-14119C But says QN75Q6DR. it is supposed to be the same, the numbers match exactly and it looks the same, the "D" is confusing me. pics 9 and 10 are old power board.
Это хороший вопрос?
3 Комментариев
@vinceelect whart is the exact make and model for your TV. Post some good pictures of your power board, main board and finally a picture of all of the boards (complete layout in the back) with your Question. That way we can see what you see and we are all one the same page in the same book.
This sounds like a panel issue. you already replaced the two most probable culprits for this. It is not uncommon for the large screens to have issues like this. We need to see more and go through some common troubleshooting before going down the panel route.
Adding images to an existing question
из oldturkey03
@oldturkey03 long time no speak, looks like its going to be a daughter now
из daniel
@tech_ni YAY! That is awesome my friend! I hope that the rest of your family is doing okay as well. You are a bit scarce these days, so how is the new job going :-)?
из oldturkey03
