Четвертое поколение смартфона Fairphone, созданное одноименным социальным предприятием. Выпущен в октябре 2021 года.
Why can't I extract the display?
Approximately two months ago, I accidentally partially destroyed the display of my Fairphone 4, and after various struggles in terms of buying and selling, today I finally managed to get a replacement ready to be installed.
I prepared myself and started the official video available on YouTube. Fully charged battery, screw container, cloth, plastic card, and screwdriver at hand. Everything is ready.
So, I begin, initially struggling a bit with the trickier screws, but soon I find the method. However, it doesn't seem to be enough because when I try to remove the screen, even though all eight screws have been removed, the bottom part, below the SIM slot, remains firmly in place.
And that's the story of how all the waiting has been wasted so far.
I also tried to disassemble the rest, but the bottom part, secured with six silver screws, even after removal, doesn't alleviate my difficulty, while the side part has hexagonal screws, so a crosshead screwdriver doesn't seem to be enough. Now I have reassembled everything except for the eight screws attached to the screen, to see if someone responds today.
Это хороший вопрос?
Счет 1
1 Комментарий:
The video I'm referring to is this one:
https://youtu.be/SUJERxuYGLI?si=JA-kqw6M...
из
Добавить комментарий
2 Ответов
@carmelo40109 we are not sure what video you are following. I would have suggest that you use the guide from here Замена экрана Fairphone 4 Going by that, all you should need is a Phillips #00 screwdriver. Post some pictures of what display you have and of the screws etc. that are giving you trouble.
Добавление изображений к существующему вопросу
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Fairphone 4 Экран Изображение
Инструкция
Сложность:
Легко
10 - 20 minutes
Был ли этот ответ полезен?
Счет 0
I finally solved it:
all I had to do was to apply more force when extracting the body at the bottom.
I followed the procedure and everything went as planned.
Whoever has the opportunity can now close the topic.
Счет 0
1 Комментарий:
Choose this post as the answer, and the topic will close.
из
Добавьте свой ответ
Carmelo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 557
