Won't grind beans
Will not grind beans, just hums
Это хороший вопрос?
Does "hum" mean, that the motor turns, or is it stuck? If it turns freely, the culprit might be a broken belt; if it's stuck there might be a little stone or something wrong between the grindstones. In any case - I fear - you have to find a way to open it and get to the grinder.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 32
За все время: 297
3 Комментариев
?? Cuisinart DCC-3200 is a coffeemaker not a bean grinder. I don't understand.
из bill
dude, it's both. You can see the bean receptacle in the device image. Most coffeemakers also have bean grinders.
из shingle
@jackiemjacobs I wonder if this is either a bad grinder or just clogged. The person that knows most about these coffee makers would be @vauweh Let's see if he can help you with this.
из oldturkey03
