The Officejet is HP's line of office inkjet printers.
Tips for printer optimization?
Hi, my dad has an HP Officejet Pro 8020 series printer, and he uses it a lot. Does anyone have any tips for getting more usage out of each ink cartridge (i.e. bypassing the sensor in the cartridges that falsely reports that they are out of ink)? I'm completely fine with tweaking the firmware, or whatever I have to do, but I just don't really know what specifically I would need to do. Any suggestions?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @shingle,
If your father doesn't mind having lesser "quality" prints, try printing with a lower resolution i.e. dpi setting or use the "draft" setting if that is an option.
Lower resolution means less ink is used.
Using the greyscale option also uses less colour ink if only printing black and white but uses the same amount of black
Just some ideas
Cheers
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
shingle буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 151
