The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
intermittent f6 code flashing on display.
Hello,
I get a f06 code on the washer when I run a complete wash cycle. I can usually run a rinse and drain cycle. I read the f06 post and tried unplugging and replugging various connectors on the CCU and MCU. I suspect a failing part, possibly a speed or rotation sensor. Where are these sensors?
Это хороший вопрос?
Счет 0
9 Комментариев:
Hi @mron,
What is the model number of the washer?
из
It's an elite quiet pack 4
из
@mron
The model number would help to ensure that if parts are required that the correct part can be found.
из
110 45972400
из
110 45972400
из
Показать ещё 4 комментариев
Добавить комментарий
1 ответ
Этот ответ изначально был на другой вопрос.
Hi @mron
There is no balance sensor in the washer. At least there's none shown in the parts list for the washer.
Intermittent problems can be hard to find so perhaps try checking the connections between the MCU and the drive motor to see if they're all OK i.e. not loose, corroded etc.
Here's the tech sheet for the washer that may also help. On p.8 it describes how to check the windings for the motor, just in case one winding is not within spec or is on the limit of what may be acceptable to the MCU.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
The tech sheet is very helpful! thanks
из
Добавьте свой ответ
Ron Moreland буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 159
