Logitech G502 Lightspeed — это беспроводная игровая мышь, которая почти полностью повторяет характеристики своего проводного аналога, G502 Hero. Номер модели MR0076. Выпущена в мае 2019 года.
Scroll wheel doesn't respond.
I used 70% isopropyl alcohol to remove fur on the inside of the wheel, but after waiting for the alcohol to dry, the scroll wheel started to respond less and less over time until now, where it does nothing.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Why use alcohol at all ??? In the future why not just use your fingers and small tweezers to pull out the hairs?
Another very important point is that 70% isopropyl alcohol is for disinfecting NOT electronics, as it has to much water in it often with minerals which leave deposits which can short electronic circuits. 99% or very close to that is preferred and is available at electronic component supply shops.
You may also have to wash the area with pure distilled water available as pharmacies. Make sure it is completely dry before using mouse again as water will short the electrical circuits.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Cadfg буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 14
За последние 30 дней: 60
За все время: 1,138
