Hi @lea66415
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
Disconnect the charger from the laptop. (if connected)
Open the laptop and remove the main battery from the laptop.
Disconnect the RTC coin cell battery from the motherboard.
Here’s the hardware maintenance manual for the laptop. Go to p.35 & p.41 to view the necessary pre-requisite steps and then the procedure to remove the main battery and the RTC battery, respectively.
Press and hold the laptop’s Power On button for a full 30 seconds and then release it.
Reconnect the RTC coin cell battery, re-insert the main battery, reassemble the laptop and connect the charger to the laptop and try to start it.
If it starts, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the laptop is started. Any user defined BIOS settings that have been altered by you to suit your particular requirements will need to be changed back also.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
5 Комментариев
Hi @lea66415,
Does it also do this with the charger connected, you didn't say?
из jayeff
yeah it does with charger connected as well.
из lea
@lea66415
Does the laptop indicate that it is charging when you connect the charger?
If so just let it fully charge before attempting to turn the laptop on, with the charger still connected and then check what happens.
It may be that the battery was very low and the charger can't do both i.e. charge a very low battery (faulty?) and run the laptop at the same time so nothing happens when you try turning it on.
из jayeff
Yes it indicates that its charging when connected to the charger.
I did that but same thing happened.
из lea
Hi @lea66415
Did you happen to get it working? I’m having the same exact issue. Thanks :)
из Aidan Amo
