The Dell Latitude E7470 is marketed as an ultraportable business laptop that is part of Latitude’s Exx70 model line. The E7470 model was released in April 2016.
Вопросов 6 Показать все
Why won’t my laptop come on?
I left my laptop uncharged for 2 weeks and when I tried charging today the power button came on. I tried turning it on but it won’t come on. I removed the battery and placed it back but it’s still the same thing. Please what can I do ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi @ayobolu
How long did you have the charger connected before trying to turn on the laptop?
If <15 minutes then leave it charging for ~1-2 hours and then after this time, check if it turns on with the charger still connected.
If it does turn on OK create a battery report to check the condition of the battery in the laptop.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they are nearly the same value.
You can work out as a percentage the condition of the battery by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value.
If the percentage is <40% you may wish to consider replacing the battery.
If you decide to replace the battery here's the owner manual for the laptop that will help.
Go to p.11 to view the procedure to remove/replace the battery. Search online for J60J5 battery to find battery suppliers that suit you best.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Ayo Bolu будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 130
