Epson Wrokforce wf-7710 all in one printer. A3+ scanner printer.
Vertical alignment very poor and seems impossible to fix
My wf-7710 has developed poor vertical alignment and the Epson procedure doesn’t seem to help. Indeed whatever I do seems to make things worse. The alignment page lines mostly show large white gaps in every position. I’m reluctant to dump it because everything else seems to work. What can I do?
Update (01/10/24)
Thanks for showing an interest. Here is an overall view of a printed page
and a closer view
an alignment page
and a closer view
Это хороший вопрос?
Счет 1
6 Комментариев
@epsonuser post an image of what a printed page looks like. that way we can see what you see and hopefully get you some idea on how to fix it. Adding images to an existing question
из
@nick take a look at this one. See if you have an idea
из
The pics are of your vertical alignment.
Row 1 is alignment 1 so you have to pick the best vertical alignment.
So your row 1 i would pick number 4.
Row two looks bad but you will have to analyze which one looks best and then repeat. You should be at all 4’s when done
из
I am having this exact problem right now in my WF-7720 and my alignment pages looks just like yours. My printer is using sublimation ink. My nozzle check shows some broken lines so I am using a syringe and tube to put hot cleaning solution through each colour to try and get rid of any blockage. It helped me get line #4 to have solid boxes (it used to have the gaps between the vertical lines). But since then, I can see no change between alignment boxes. I changed the re-fillable ink cartridges to new ones and topped up each cartridge with fresh ink. Still no change. I print lots of purge sheets and they come out with some streaks, so my plan is to continue with the hot cleaning solution over the next month. If no improvement, I am guessing my printer head is defective maybe. After the cleanings and when I get ink flowing again, I try doing many vertical alignments but I can't tell aside from line 1 and 4 that there is any difference. If I get any new improvement, I will update here.
из
Hi All, I am back and I have just solved my alignment issue! I was having the same issues as the original poster with large gaps between the boxes that should be solid. This worked for me. Choose one line and ignore all the rest. So looking at the image above, I would pick line 3 for example. Run the print alignment. When it asks you to choose the best looking, ignore that. For all lines, except line 3 choose the number 4 (this keeps the current setting the same). For line 3, choose the number 7. Run the alignment again. Do these exact same steps (picking 7 for line 3 and 4 for the rest). Do this over an over and over. You should see the gap on line 3 starting to get smaller. For me, it seemed like picking 7 made the boxes move to the left. They moved in 'big' steps. As the line got close to becoming a solid box, I started choosing 6 or 5 to make the movements 'smaller'. Then I did this for all the other lines. It took a good 60+ alignments to do all lines. If 7 doesn't work for you try choosing 1
из
Показать ещё 1 комментарий
Добавить комментарий
2 Ответов
Выбранное решение
There is a solution! (Unfortunately too late for me.) See Kerrie’s comment, #5 in the list.
Был ли этот ответ полезен?
Счет 0
The printer is not broken. The vertical alignment maintenance function has become too far out for the printer correction controls to print within the range necessary for you to see how to correct it on the printout. It is fixable and Kerrie has indicated the answer. Comment No 5.
I have elaborated on this with more information, hope it helps.
If on the vertical head alignment printout, on any numbered row, the heavy colour line is to the LEFT and the space is to the RIGHT in each box then choose "1" in the correction question on the printer.
If on the vertical head alignment printout, on any numbered row, the heavy colour line is to the RIGHT and the space is to the LEFT in each box then choose "7" in the correction question on the printer.
If it is hugely out this procedure will need to be done multiple times before you see a noticeable difference in the boxes becoming full again and within the range again where you can choose the correct box on the printout. You may see little or no change at all in the first few passes. Perseverance is the key here!
Good luck.
Счет 0
Добавьте свой ответ
Epson user буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 39
За последние 30 дней: 129
За всё время: 1,277
