Overload message when brewing starts
When brewing coffee pod, overload message turns on and coffee machine stops
Это хороший вопрос?
Это хороший вопрос?
Hey, @val21350
I can't say for sure how to fix it as you don't have a specific model listed, but here's some advice. Open the device, and take a look at all the sensors and tubing. Make sure you're 100% certain that there aren't any clogs or offset/dislodged sensors. If you moved the coffee machine with a pod or water in the machine (if it's newer, old ones used pots so this wouldn't be possible), it may have become plugged or a sensor may have been loosened. Additionally, if it was moved while storing water then the water may have sloshed and gotten somewhere it doesn't belong, so check all boards and circuits for water damage. Good Luck.
Был ли этот ответ полезен?
Re: Hamilton Beach FlexBrew. My K-pod side kept reading overload error. My fix after trying different things - put the end of a turkey baster on the needle and applied a few rounds of suction, drawing out about 3/4 cup of clean water. This worked good
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 917
Hi @val21350,
What is the make and model number of the coffee maker?
из jayeff
