Замена конденсатора
36 Ответов 262 Оценка |
My Keurig makes brewing noises but doesn't brew. |
37 Ответов 11 Оценка |
Why is my Keurig Classic constantly turning off while brewing? |
19 Ответов 46 Оценка |
Light blinking two times, pause, two times, etc. |
8 Ответов 17 Оценка |
My Keurig Will not draw water |
Документы
Запчасти
- Delonghi Water Tank - AS13200250
- Delonghi Rubber Cleandisk (Black) - AS00001634
- Delonghi Filter 1-Dose Coffee with Rib - AS00002564
- Delonghi Glass Carafe - HZ1029
- Delonghi Water Tank - AS13200251
- Delonghi Carbon Filter - 7313285779
- Delonghi Infuser Diffuser Kit - 7313251451
- Delonghi Infusion Kit with Black Push Button - 7313251441
Инструменты
Модели
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC Показать ещё 272
BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
Общие сведения
Кофеварки - это приборы, предназначенные для удобного приготовления кофе дома или в коммерческих условиях. Они бывают разных типов, в каждом из которых используются различные методы извлечения аромата из кофейной гущи.
Типы
Капельные кофеварки
Кофеварки с заливкой кофе
Кофеварки с переливом - это устройства для приготовления кофе вручную, которые позволяют любителям кофе лучше контролировать процесс приготовления. Основная конструкция состоит из воронки или конусообразной капельницы, в которую вставлен бумажный или металлический фильтр. Молотый кофе засыпается в фильтр, и на него медленно, контролируемо наливается горячая вода.
Кофеварки с автоматическим капельным режимом приготовления кофе
Авто-капельные кофеварки, также известные как автоматические кофеварки capri, являются популярными электрическими устройствами для приготовления кофе, разработанными для удобства и простоты использования. Авто-капельные кофеварки автоматизируют процесс приготовления кофе. Вы наливаете воду в емкость, помещаете молотый кофе в фильтровальную корзину и включаете кофемашину. Вода нагревается, а затем высыпается на кофейную гущу. Сваренный кофе проходит через фильтр в кофейник или графин, который устанавливается на нагревательную плиту, чтобы сохранить кофе горячим. В некоторых моделях есть такие функции, как регулировка крепости и времени заваривания.
Кофеварки для заваривания кофе
Кофеварки для холодного заваривания кофе
Кофеварки для холодного заваривания кофе - это устройства, предназначенные для простого и эффективного приготовления холодного заваривания кофе. Обычно они включают замачивание кофейных зерен крупного помола в холодной воде или воде комнатной температуры на длительный период, обычно на 12-24 часа. В результате получается однородный, менее кислый кофейный концентрат, который можно разбавлять водой или молоком перед употреблением. Такие кофемашины часто оснащены фильтром или сетчатой системой для отделения гущи, что делает процесс заваривания удобным и не допускает путаницы.
Френч-пресс
Френч-пресс - это простое и эффективное устройство для приготовления кофе. Он состоит из цилиндрической емкости из стекла или нержавеющей стали с поршнем и металлическим сетчатым фильтром. Для приготовления кофе кофейные зерна крупного помола замачиваются в горячей воде внутри пресса. Через несколько минут поршень нажимается, отделяя кофейную гущу от заваренного кофе. Этот метод позволяет получить чашку с насыщенным вкусом, поскольку кофейная гуща остается в непосредственном контакте с водой в процессе заваривания.
Кофеварки по-турецки
Турецкие кофеварки, известные как «Джезва» или «Ибрик», представляют собой традиционную посуду для приготовления кофе по-турецки. Обычно эти небольшие кофейники изготавливаются из меди или латуни и имеют длинную ручку и широкое основание. Кофе мелкого помола, вода и сахар (по желанию) смешиваются в джезве и нагреваются на слабом огне. Уникальный процесс заваривания заключается в многократном доведении смеси почти до кипения, в результате чего получается крепкий, концентрированный кофе с густой пенкой, известный как "каймак". Кофейная гуща мелкого помола оседает на дне, придавая кофе неповторимый и насыщенный вкус.
Кофеварки, работающие под давлением
AeroPress
AeroPress - это компактная кофеварка, созданная для простоты и универсальности использования. Она состоит из цилиндрической камеры с поршнем и крышки фильтра. Чтобы сварить кофе, пользователи помещают кофейную гущу и горячую воду в камеру, перемешивают, надевают крышку фильтра и нажимают на поршень для извлечения кофе. Уникальная конструкция кофемашины обеспечивает быстрое и легкое заваривание и известна тем, что позволяет получить чашку однородного и насыщенного кофе, контролируя параметры заваривания. Кофеварка AeroPress популярна среди любителей кофе благодаря своей портативности, доступности по цене и возможности экспериментировать с различными технологиями приготовления.
Moka Pot
Кофеварка Moka Pot - это настольная кофеварка, которая позволяет варить крепкий и ароматный кофе, пропуская кипящую воду под давлением пара через молотый кофе. Он состоит из нижней камеры для воды, средней воронки для кофейной гущи и верхней камеры для окончательного заваривания. Когда вода нагревается, давление прогоняет ее через кофейную гущу, в результате чего получается насыщенный и концентрированный кофе, известный как Мокка. Этот процесс прост, быстр и популярен благодаря своей способности готовить крепкий кофе с характерным вкусом, чем-то похожим на эспрессо.
Кофеварки для одноразовой подачи
Кофеварки для приготовления кофе на одну порцию - это компактные и удобные устройства, предназначенные для приготовления отдельных порций кофе. В них используются предварительно упакованные кофейные капсулы, что позволяет пользователям быстро и легко приготовить одну чашку кофе с минимальными усилиями и беспорядком. Эти кофемашины предлагают широкий выбор вариантов приготовления кофе на любой вкус и отличаются простотой и экономией времени.
Эспрессо-машины
Кофеварки эспрессо, широко известные как эспрессо-машины, представляют собой специализированные кофейные устройства, предназначенные для приготовления концентрированного кофе путем пропускания горячей воды через кофейные зерна мелкого помола. Они работают под высоким давлением, обычно около 9 бар, для извлечения из кофейной гущи насыщенных вкусовых и ароматических компонентов. Эспрессо отличается крепким и насыщенным вкусом, а также слоем сливок, образующейся сверху кремообразной пенкой. Эти кофемашины бывают различных типов, включая ручные, полуавтоматические и автоматические, что позволяет пользователям по-разному контролировать процесс приготовления.
Полностью автоматические кофемашины
Полностью автоматические кофемашины - это современное оборудование, упрощающее процесс приготовления кофе. Эти кофемашины справляются со всеми задачами, от измельчения кофейных зерен до заваривания, устраняя необходимость в ручном вмешательстве. Пользователи могут настраивать такие параметры, как размер помола, крепость кофе и тип напитка, поскольку эти машины могут готовить различные напитки, включая эспрессо, капучино, латте и обычный кофе. Благодаря встроенным кофемолкам и автоматическим системам заваривания они обеспечивают удобство и консистенцию приготовления свежезаваренного кофе с минимальными усилиями.
Перколяторы
Кофеварки-перколяторы - это традиционные устройства для заваривания кофе, которые состоят из кофейника, центральной трубки и перфорированной корзины. Вода в кофейнике нагревается, и возникающее в результате этого давление выталкивает ее вверх по трубке и через кофейную гущу в корзину. Затем сваренный кофе поступает обратно в кофейник, создавая непрерывный цикл, пока не будет достигнута желаемая крепость. В прошлом были популярны кофеварки-перколяторы, но из-за различий в способах приготовления и вкусовых предпочтениях их заменили на капельные кофеварки.
Сифонные кофеварки
В сифонных кофеварках, также известных как вакуумные кофеварки, используется привлекательный для глаз и основанный на физике метод приготовления кофе. В нижней камере, состоящей из двух камер, вода нагревается, создавая давление пара, которое заставляет воду перемещаться в верхнюю камеру, где находится кофейная гуща. При выключении нагрева сваренный кофе возвращается в нижнюю камеру под действием вакуума. В результате этого процесса получается уникальный ароматный кофе с мягким и чистым вкусом, подчеркивающим вкусовые качества зерен.
Дополнительная информация
Особая благодарность этим переводчикам:
100%
Pavel помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
