Error code is eet?
What does this code mean?
Это хороший вопрос?
That error code is not shown in the tech sheet for your model.
What is happening with the washer? Does it work OK or if not, what doesn't work e.g. fill, wash, dispense detergent, drain, rinse, spin etc?
Go to p.7 in the tech sheet to see the procedure to perform the diagnostic tests and check if any error codes are shown by the tests.
If there are any, then on p.2→p.6 you'll find the error codes and possible causes and checks.
Post back with any results if you need any further assistance.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 15
За все время: 249
2 Комментариев
Hi @nancywillman
What is the model number of the washer?
из jayeff Поделиться
Model number is 11045972400
из Nancy Willman Поделиться
