Ground Hog Augers (model HD99-H) are towable hydraulic augers with variable forward speed and reverse auger rotation. The HD99-H model can dig holes with any auger with up to 18-inch diameter.
Where can I find the proper bit
We have the HD-99 not the HD-99H and when we order the bits from Ground Hog they send us a bit that is too shallow and will not fit. The current bit is a SB-25 with the number 1986 stamped above. The Drill itself has 12-C5 stamped on the bottom of the drill. There is a decal that has DC-DARA on the shaft of the drill. Can anyone help me with getting this bit as we have none of the bits working that came with the unit. Thank you
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @jobewood
Can't find the bits as per the info you posted but if you don't get a better answer perhaps try using a suitably sized hub adapter to get the bits you already have working.
If there is a suitable size adapter listed for the auger and the bits sizes, search online for Pengo (insert part number (pn) of adapter) to find suppliers that suit you best.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Jobe Wood буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 223
