It sounds like your laptop's battery life has significantly decreased, and you're also experiencing increased fan activity. Several factors could contribute to these issues, including the battery itself, software changes, or hardware problems. Here are some steps you can take to diagnose and potentially address the problem:
1. Check Battery Health: Many laptops have built-in diagnostics tools that can assess the health of your battery. Check your laptop's user manual or manufacturer's website for instructions on how to access these diagnostics.
2. Monitor Resource Usage: Use your operating system's task manager or activity monitor to identify any processes or applications that are consuming an unusually high amount of CPU or memory. This could help pinpoint the source of the increased fan activity and potentially address it by closing or uninstalling problematic programs.
3. Review Recent Changes: Reflect on any recent changes you've made to your system, such as installing new software or updates. As you mentioned, the virtual machine software could be contributing to the increased fan usage. Consider temporarily disabling or uninstalling the software to see if it improves battery life and fan activity.
4. Reset Power Management Settings: Sometimes, power management settings can become corrupted or misconfigured, leading to decreased battery life. Resetting these settings to their default values may help. You can typically find power management settings in your laptop's control panel or system preferences.
5. Update Drivers and Firmware: Ensure that your laptop's drivers and firmware are up to date. Manufacturers often release updates to address performance issues and improve compatibility with software updates.
6. Perform a Battery Calibration: Some laptops benefit from occasional battery calibration, which involves fully charging and then completely draining the battery to recalibrate its capacity readings. Consult your laptop's documentation for instructions on how to perform a battery calibration.
7. Consider Battery Replacement: If none of the above steps resolve the issue, it's possible that your battery has reached the end of its lifespan and needs to be replaced. Contact your laptop manufacturer or a certified repair technician to inquire about battery replacement options.
In summary, while a battery replacement may be necessary if your laptop's battery health is poor, it's worth exploring other potential causes first, such as software issues or recent changes to your system. By systematically troubleshooting and addressing these factors, you may be able to improve your laptop's battery life and reduce fan activity without the need for a replacement.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
Battery problems on the zenbook duo series is a normal problem.
The laptop comes with the MYASUS app.
Run a diagnostics it will tell you whether there is a problem with it
If it doesn't show you need to check the Battery health
If you use windows 10:
Open the Start menu by clicking it (or by pressing the Windows key on your keyboard) and launch the Command Prompt.
Next at the end of the prompt type powercfg /batteryreport
Assuming everything went smoothly, you should see a message in the Command Prompt informing you that a battery report has been saved to your user folder
Go to file Explorer and go to "This pc"
Go to devices and drivers
There you will see battery report
Left click and you will be redirected to a tab with the info you need.
If you use windows 11: it is the same.
WHEN IT COMES TO THE FAN
go to pro art creator hub and you will be given choices of how fast you want your fan to spin
Hope this helps
из NURDIN ADAN
