Upgrading memory on MacBook
I see other questions and answers about updating MacBook from 2GB of RAM to possibly 6GB, but I am a complete beginner when it comes to computer terminology and I was hoping someone could please verify that I could do that same on my computer. Here's some info I can find about my laptop:
Model Name: MacBook
Model Identifier: MacBook6,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.26 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
Serial Number (system): W89518EC8PW
I have no idea what any of this means. I don't even know what RAM is, but was recently told I should increase the memory on my computer. (I guess that's RAM??) Please help!
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Here's the stats on your machine:
http://everymac.com/systems/apple/macboo...
Apple MacBook "Core 2 Duo" 2.26 13" (Uni/Late 09) Specs
Identifiers: Late 2009 - MC207LL/A - MacBook6,1 - A1342 - 2350*
It will take two 4GB sticks of RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
Here's the correct guide for installing the RAM: MacBook Unibody Model A1342 RAM Replacement
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
My bad. I'll remove the wrong guide. The MacTracker hint still stands.
из
You should download "MacTracker", is an OS X software that gives you stats over every machine built, including max ram and OS supported.
You could go up to 8Gb, but I don't think you'd ever need that much. It's odd they told you to update without you having any issue.
Are there applications that run slow? If you feel your laptop sluggish, and you do, for example, lots of Videogame playing and graphic editing, you may enjoy some more Ram.
If your issue is different, for example lacking space to store your media, you could enjoy instead a bigger Hard Disk, or an external unit.
However, if you need Ram, follow the guide given by Meyer and check the ram chips sold on this site.
Ram Upgrade is one of the easiest things you can do by yourself, even without practice.
Счет 2
1 Комментарий:
Stefano, you can't be sloppy. You didn't look the machine up, thus giving the wrong guide.
из
Добавьте свой ответ
gsdfdhg56y34 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 5,038
