Холодильники производства Samsung.
Water Dispenser Water Stream
My refrigerator model is RF28K9380SR/AA Flex. The water dispenser was working as expected until I changed the water filter. Now it still works except that the water stream continues for a couple of seconds after taking the glass away. The water doesn't shut off as it should. I have made sure there is no air anywhere, reseated the water filter and even reset the refrigerator. I have also tried without the filter with the same results.
I live in a condo that has significant water pressure. I'm guessing between 80 and 100 PSI. But the refrigerator has been working fine up until the filter change.
Any idea? Just as an FYI, I live in Costa Rica so support options are limited.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @tonyprice8144
According to p.32 of the user manual the ice maker should work at pressures between 20-125 psi so water pressure of 80-100psi should be OK
It could be a faulty water dispenser valve i.e. weak restore spring tension perhaps. although why the problem occurred after a filter replacement seems odd - coincidence maybe??
Either that or the problem is electrical and the control board is not disconnecting the power to the valve as soon as the dispenser switch is released.
Try temporarily inserting a pressure reducing valve between the water supply connection from the refrigerator and where it connects to the household water supply and see if this resolves the problem. If it does, then it does seem like a faulty valve.
The Samsung part number for the water valve assembly¹ in your refrigerator is DA62-04027A.
Here's some information that may help if it is the valve.
Video that shows where the valves are located in the filter case assembly.
Video that shows how to remove the filter case assembly so that you can access the valves.
A link to the service manual which may also help. There's no option to download it to make it easier to use, but it still may be of some use as you can scroll through the pages or select the page you want by changing the page number in the page number/ magnifying option box at the bottom of the page in the guide and press Enter. Then to view it more clearly click on the + sign a few times to suit. Note: If the manual isn't there when you first click on the link, refresh the page e.g. for Windows OS press the F5 key
¹ It is a complete unit, consisting of two valves. There is one for the ice maker and one for the water dispenser. These are not individually replaceable valves. If either are faulty they are irreparable as there are no internal valve parts sold separately, so you will need to buy the complete unit. Search online for the part number to find suppliers that suit you best.
Supplies water to your refrigerator's ice maker and water dispenser. Изображение
Товар
DA62-04027A - Samsung Water Inlet Valve
$158.99
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Tony Price буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 19
За всё время: 196
