Replaced LVDS cable; no video
Hello everyone,
I recently replaced the LVDS cable in an imac a1418-emc3069
The machine fires up with the famous apple chime.
I have 3 LEDs shining bright and the 4th is on but dim.
Any advice? Let me know if there is anymore information I can provide to assist thank you
Это хороший вопрос?
Счет 0
11 Комментариев:
Can you explain why you replaced the video cable (FYI this is a eDP cable)
из
I was upgrading the RAM -- Its a 60 pin cable. The end of the orgiginal cable had to some damage to it. The sockets dont seem to be damaged. I purchased two identical cables without a positive attempt.
из
Ive done this a few times and havent ran into this issue before.
из
Did you follow this guide and use the special cutter tool?
из
I did. The breakdown and Reassembly went without issue. Had Black Screen with new RAM.
Removed new and reinstalled the original RAM - black screen.
из
Показать ещё 6 комментариев
Добавить комментарий
