There is a black line on my screen
there is a black line on my screen the drivers are updated. screenshot dontshow the line.
Update (09/08/24)
this is the screen
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
@deryaduygut2145 that will depend on how thick this line is. If it is a thin line the issue is most commonly a TAB error. That is where one of the COF ribbon cables looses connection to the LCD screen. This can't be fixed by us DIY'er since it is attached via a special process. Sometimes applying pressure to the ribbon will close the contact and the line will disappear. If it is a thick line it is possible that this is a LVDS cable issue. Post an image of what your screen shows with your Question. That way we can see what you. For now, it seems like you will need a new display to fix this.
Use the Lenovo Ideapad 5 Hardware Maintenance Manual to work on it. Page 58 will tell you how to replace the LCD
Adding images to an existing question
Update (09/08/24)
@deryaduygut2145 that is definitely a cracked screen there is no fixing it. You will need a new LCD.
Был ли этот ответ полезен?
Оценка 0
You for sure will need a new screen. That "line" is caused by an internal crack.
Оценка 0
Добавьте свой ответ
derya duygu tanrıkulu будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 12
За последние 30 дней: 12
За всё время: 37
