Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312вопросов Показать все
Вопрос закрыт
top LCD panel hinge pins
Ok i got a macbook air a1237 that I'm repairing as a hobby. I've so far replaced the screen and now I'm trying to fix the hinges on the LCD top part. what I'm looking for and hopefully someone can point me to the right direction is the pins the attach to the hinge. they are little semi-circle clips with a flat top part that attach to the rod on the hinge. usually so i have been told that there are at least 20 pins per hinge this keeps the top LCD panel standing firm at any angle.
so anyone know where i can buy these pins, i have look on ebay but i have found nothing. i have a set of LCD hinges and a set of case hinges all i need is the pins that attach to the rods of the LCD hinges.
Thanks in advanced
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
'''Look at this previous Question. What you are actually looking for is the lower display bracket.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
thanks for the reply but I'm not after the bracket I'm after the pins that attach to the bracket
из
You mean the thirteen 2.3 mm Phillips screws?
из
sorry for not being clear, these things.
I have the LCD hinges and the case hinges, but i need about 20/30 of these pins that attach to the LCD hinges on the left and right.
http://i1103.photobucket.com/albums/g477...
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,015
