MacBook Air Models A1237 and A1304 Display Assembly Replacement
Выберете то, что вам нужно
Видеообзор
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Lower Case: шаг 1, изображение 1 из 1
      • Unplug your MacBook Air and power it off before you proceed.
      • Remove ten Phillips screws securing the lower case to the MacBook Air:
      • Six 2.8 mm screws
      • Two 3.8 mm screws
      • Two 5.4 mm screws
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 2, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 2, изображение 2 из 2
      • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
      Спросите у FixBot
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Battery: шаг 3, изображение 1 из 1
      • Disconnect the battery connector by pulling it straight out of its socket.
      Спросите у FixBot
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 4, изображение 1 из 1
      • Remove the following nine screws securing the battery to the Air:
      • Four 2.9 mm Phillips.
      • Four 3.8 mm Phillips.
      • One 7.2 mm Phillips.
      Спросите у FixBot
    3. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 5, изображение 1 из 1
      • Lift the battery out of the Air.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Спросите у FixBot
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 1 из 3 MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 2 из 3 MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 3 из 3
      • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
      • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
      • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
      Спросите у FixBot
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 7, изображение 1 из 1
      • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
      Спросите у FixBot
    3. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 8, изображение 1 из 1
      • Use a spudger to pry the hard drive cable connector up off the logic board.
      Спросите у FixBot
    4. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 9, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 9, изображение 2 из 2
      • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
      • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
      Спросите у FixBot
    5. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 10, изображение 1 из 1
      • Remove the four Phillips screws securing the hard drive assembly to the upper case:
      • Two 4.7 mm screws.
      • Two 3.9 mm screws.
      Спросите у FixBot
    6. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 11, изображение 1 из 1
      • Lift the hard drive assembly out of the upper case.
      Спросите у FixBot
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Heat Sink: шаг 12, изображение 1 из 1
      • Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
      Спросите у FixBot
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 13, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 13, изображение 2 из 2
      • Use the tip of a spudger to move the cosmetic fan cover aside.
      Спросите у FixBot
    3. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 14, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 14, изображение 2 из 2
      • If you have the original version of the MacBook Air (A1237), refer to picture 1. Remove the following screws securing the heat sink to the logic board:
      • One 5.9 mm Phillips screw.
      • Two 1.9 mm Phillips screws.
      • One 1.9 mm Phillips screw.
      • If you have the A1304 version of MacBook Air, refer to picture 2. Remove the following screws securing the heat sink to the logic board:
      • One 5.0 mm Phillips screw
      • Five 1.9 mm Philips screws.
      • One 2.5 mm Phillips screw.
      Спросите у FixBot
    4. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 15, изображение 1 из 1
      • Lift the processor clamp off the heat sink.
      Спросите у FixBot
    5. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 16, изображение 1 из 1
      • Deroute the microphone cable away from the channel in the fan.
      Спросите у FixBot
    6. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 17, изображение 1 из 1
      • Lift the heat sink up off the logic board.
      • Be mindful of the microphone cable when lifting the heat sink, as it can get tangled on the top edge of the fan.
      • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
      Спросите у FixBot
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Logic Board: шаг 18, изображение 1 из 1
      • Use a spudger to pry the audio cable connector up off the logic board.
      Спросите у FixBot
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 19, изображение 1 из 1
      • If present, remove the small piece of black tape covering the microphone cable connector.
      • Disconnect the microphone cable by pulling its connector straight away from the socket on the logic board.
      Спросите у FixBot
    3. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 20, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 20, изображение 2 из 2
      • Remove the two small Phillips screws securing the logic board bracket to the upper case.
      • Lift the logic board bracket out of the upper case.
      Спросите у FixBot
    4. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 21, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 21, изображение 2 из 2
      • Use a spudger to pry the AirPort/Bluetooth and trackpad control cable connectors up off the logic board.
      Спросите у FixBot
    5. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 22, изображение 1 из 1
      • Disconnect the DC-In cable by pulling its connector straight away from the socket on the logic board.
      Спросите у FixBot
    6. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 23, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 23, изображение 2 из 2
      • Remove the small Phillips screw securing the display data cable ground loop to the upper case.
      • Disconnect the display data cable by pulling its connector straight away from the socket on the logic board.
      Спросите у FixBot
    7. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 24, изображение 1 из 1
      • Remove the three Phillips screws securing the logic board to the upper case.
      Спросите у FixBot
    8. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 25, изображение 1 из 1
      • Lift the logic board out of the upper case.
      Спросите у FixBot
    1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Display Assembly: шаг 26, изображение 1 из 1
      • Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
      • One 4.7 mm Phillips.
      • One 3.9 mm Phillips.
      Спросите у FixBot
    2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 27, изображение 1 из 1
      • Lift the AirPort/Bluetooth bracket out of the upper case.
      Спросите у FixBot
    3. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 28, изображение 1 из 1
      • Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
      Спросите у FixBot
    4. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 29, изображение 1 из 1
      • Peel the antenna cables up off the adhesive securing them to the upper case.
      Спросите у FixBot
    5. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 30, изображение 1 из 1
      • Remove the single Phillips screw securing the microphone cable ground loop to the upper case.
      Спросите у FixBot
    6. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 31, изображение 1 из 1
      • Remove the following 15 screws:
      • Thirteen 2.3 mm Phillips.
      • Two T6 Torx.
      • Leave one T6 Torx screw in each side of the display bracket.
      Спросите у FixBot
    7. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 32, изображение 1 из 1
      • Open the Air so the display is perpendicular to the upper case and place it on a table as shown.
      • While holding the top of the Air with one hand, remove the T6 Torx screw from the lower display bracket.
      Спросите у FixBot
    8. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 33, изображение 1 из 1
      • Be sure to hold the Air together while you remove the last Torx screw. Failure to do so may cause the display/upper case to fall, potentially damaging both components.
      • Remove the T6 Torx screw from the upper display bracket.
      Спросите у FixBot
    9. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 34, изображение 1 из 1
      • Pull the upper case straight away from the display, minding any cables that may get caught.
      Спросите у FixBot
Заключение
118 человек успешно провели ремонт по этому руководству.
8 Комментарии к руководству
Great guide. I was able to remove the components without any trouble. Be sure to label your screws, as there are so many.
Steven Hanlon - Ответить Поделиться
Do you have a guide to put that macbook back togerher?
Antonio Korts - Ответить Поделиться
I was able to replace broken hinges without replacing the whole display. It takes patience and a bit of courage but it's doable (except if you are blonde and cute I guess ;)
Alfredo Sola - Ответить Поделиться
Buenas tardes Alberto. Tengo necesidad de sustituir una bisagra de este modelo y no sé donde puedo adquirirla. Le agradecería que me dijera donde puedo comprarla. muchas gracias por adelantado
jose enrique guijarro martinez - Ответить Поделиться
Thanks for the guide. My internal microphone stopped working but unfortunately I was not able to fix it. Still, very helpful guide.
pentzini - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 18
За последние 30 дней: 74
За всё время: 185,134
