Xiaomi Poco X3 Pro - это смартфон бюджетного сегмента от Xiaomi, выпущенный в марте 2021 года. Он оснащен 6,67-дюймовым IPS ЖК-экраном, основной камерой на 48 Мп и процессором Qualcomm Snapdragon 860.
My phone was fall in water. It cant on..
My phone fall in water and it cant on. After 3 days, i try charge my phone but it not turn on the screen, just the led light keep blink.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @mawarhitam
The phone is not waterproof and only has an IP53 waterproof rating. According to Xiamio (see 6. Q) "... it supports ordinary life anti - splash water. In addition, life dustproof spillage function will be reduced due to daily wear and tear, not permanent effective. Do not charge your mobile phone in wet condition".
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is video that will help with disassembling the phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Mawar Hitam буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 145
