Philips TP Vision 50PUS7805
I have sound all the time but the picture comes and goes. I had horizontal lines along the bottom few inches of the tv for the last year or more.
Это хороший вопрос?
Это хороший вопрос?
@babarmirza since you said the pictures comes and goes, that could actually be the backlight turning on and off due to failing and overheating backlight strips. Let us know how long the screen stays black. If it is long enough, then you could try and shine a flashlight beam at an angle against the screen. If you can still make out your images then you know it is the backlight strips.
It is also possible that this is a bad panel. Based on the horizontal stripes. Horizontal stripes are always caused by a failed GATE driver which are considered part of the panel.
If you can, post some images of what your TV displays while the screen is working. Adding images to an existing question
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 85
