Nintendo GameCube — четвертая игровая консоль компании Nintendo. Ремонт устройства прост и требует только стандартных инструментов.
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
Это хороший вопрос?
Счет 0
1 Комментарий
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
из
Glad that a new memory card did work! Have a great day :)!
из
Добавьте свой ответ
Nirby 74 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 220
