Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why will my psp go not turn on?
When the power switch is pressed the green light flashes for a second, but the unit doesn't power up. When the unit is charging the charging light is on, but it still wont power up. When the unit is plugged into the PC it is not recognized. Without disassembling the unit I am not able to do anything else with it.
Это хороший вопрос?
Счет 3
1 Комментарий
how to fix psp go wifi not supported
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Nope, no Pandora's Battery for the Go. It has a simple two-conductor battery, that's it. If it has any power at all and isn't starting, it doesn't seem like a mechanical problem, but something wrong with the mainboard. I think it needs a trip to Sony, sorry.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
You might be able to use the "Pandora Battery" technique to unbrick it. I'm not sure how it's done on this model, but it wouldn't hurt to give it a try.
из
It sounds bricked, you should send it to Sony and see if they will replace it.
Счет 1
buenas mi psp go estando encendida le quitaron la tapa de atras y no encendio mas y le pongo el cargador y prende el led naranja pero no enciende espero y me puedan ayudar sera algun fusible en la placa
Счет 0
Blown Fuse maybe?
http://www.mr-vizitkin.ru/images/stories...
^^ Fuses for PSP GO.
The one on the right is for Audio - so the one *under* the metal shielding may well be your power Fuse. I would suggest testing with a multimeter to confirm.
If you are going to bridge it then a Circuit Writer pen is the easiest - just practice on something other than the psp so you get used to the flow.
Счет 0
2 Комментариев:
How do you get under the metal shields?
из
Ill be honest with you - they do pop off with a little pressure and a watchmakers screwdriver - just like on an iphone 3g main board. Just *break* the soldered joint and you will be under the shield.
из
you are a !@#$%^& idiot
Счет 0
Добавьте свой ответ
Tom буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 23,810
