Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Battery will not charge and computer will not run unless plugged in.
My MacBook will not charge or stay on without the magsafe plugged in.
I have replaced the battery connector and the magsafe DC-in board. While it is plugged in the magsafe cable shows orange and the computer shows the charge indicator symbol (little lightning bolt), but it says 0%. And it is a new battery.
Coconut reads;
Battery Charge;
-Current charge: 0 mAh
-Maximum charge: 4200 mAh
Battery Capacity;
-Current capacity: 4200 mAh
-Design capacity: 4000 mAh
Details;
-Mac model: MacBook4,1
-Age of your Mac: 51 Months
-Battery loadcycles: 61
-Battery temperature: 29.9 C/85.8 F
-Battery power usage: Charging...
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Have you tried with a friends (known working) battery? The fact that it is new is usually good enough to assume it's in proper working condition, but does not always guarantee it. Before sending it back or buying a new one, I'd suggest trying a battery that works in another computer first if possible
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Stephen Perry будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,166
