Руководства по ремонту, разборке и устранению неисправностей смартфона Xiaomi Redmi 12C на базе Android (включая модель 23028RNCAG).
I can't use my camera
When i wanna take a picture or flash something i can't use my camera
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
1. Restart the phone
  • Simple but often effective.
  • Hold the power button → tap Restart.
2. Check permissions
  • Go to Settings > Apps > Camera > Permissions.
  • Make sure Camera, Microphone, and Storage permissions are allowed.
3. Clear Camera app cache
  • Go to Settings > Apps > Camera > Storage & Cache > Clear Cache.
  • If that doesn’t work, try Clear Data (this resets camera settings).
4. Test with Safe Mode
  • Hold Power button, then long-press Power off → tap Reboot to Safe Mode.
  • Open the Camera app in Safe Mode.
    • If it works → another app is conflicting.
    • If it still fails → likely system or hardware issue.
5. Check Flash
  • Open Camera → switch to Photo mode, then toggle flash.
  • If flash won’t turn on or shows an error → it could be a hardware issue.
6. Update software
  • Go to Settings > About phone > System update → install any pending updates.
7. Factory reset (last resort)
  • Backup your data first.
  • Go to Settings > About phone > Factory reset.
  • This removes software glitches that might block the camera.
Был ли этот ответ полезен?
Счет 1
When I want to take a picture with my front camera hey will now count 3secound and remove
Счет 0
Yes I am using your camera and flash
Счет 0
Добавьте свой ответ
Keisha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 43
За всё время: 370
