Руководства по ремонту, разборке и устранению неполадок Apple iPad 10-го поколения, доступного в версиях с Wi-Fi и сотовой связью, с объемом памяти 64 или 256 ГБ. Выпущен в октябре 2022 года. Идентифицируется по номерам моделей A2696, A2757, A2777 или A3162.
My iPad won't charge
So my iPad won't charge. When I first bought it (used) it had some charging issues but after some time it worked fine. I sometimes had to turn the Cable because it didn't charge. But now it completely stopped charging. If I connect the charger it does nothing, if i turn it off and connect it, it boots automatically and a message pops up saying "Accessory connected" but it still wont charge. The Port is clean and I've tried many different Cables, including the original one.
About the "Accessory connected" Message, my iPad 7 keeps getting the same message but charges perfectly fine.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
From your description, it sounds like the charging port is starting to fail internally. The “Accessory connected” message usually points to the iPad detecting the cable but not making a solid power connection. Since you’ve already tried multiple cables and cleaned the port, the next step is checking the charging port itself—it may be loose, worn, or have damaged pins.
In many cases, replacing the charging port assembly fixes this completely. If not, it could be a charging IC issue on the logic board, but port replacement is the most common solution.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
flo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 15
За всё время: 283
