Более доступная, исключительно портативная версия игровой консоли Nintendo Switch со встроенными контроллерами Joy-Con и чуть меньшим экраном. Выпущена 20 сентября 2019 года.
Volume up button doesn't work.
I got a new cat recently who required some training, and unfortunately, I think she urinated on my switch. The only issue I've noticed since cleaning it is that the volume up button no longer works. The volume down button works, the power button works, everything else seems fine, I just can't turn the volume up, and there's no setting in the Switch itself to adjust volume either. I have not yet tried anything to fix it because I'm quite inexperienced working on electronics myself, but if there is a way to fix it myself, I'll certainly try. The button does not appear to be stuck; it presses down and up normally, but it just doesn't do anything.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi there!
Yes, those buttons are replaceable!
Your in luck I guess :)!
You can follow this guide: Замена экрана Nintendo Switch Lite (from step 41 all the way till step 43).
So you dont need to remove the motherboard or other components!
If you have any questions, please let us know!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kai Hayden буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 181
