Ноутбук Lenovo ThinkPad E15 Gen 2 был выпущен в 2020 году. Он может быть оснащен процессором Intel Core 11-го поколения (i3/i5/i7) или процессором AMD Ryzen серии 4000.
Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
  • Power off the device and carefully clean the port using compressed air or a non-metallic tool (such as a wooden or plastic pick).
  • Inspect the port with a flashlight for visible damage or corrosion.
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Adrian буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 25
За последние 30 дней: 73
За все время: 445
