Why it won't open?
it has no battery, so we we're using it's own charger to open it. after using it a long time, it won't open like it usually do whenever we're opening it. I wonder why?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
1 'Head reset' unplugging the adapter and hold the power button for 30 seconds to drain the residual power.
Faulty Power Adapter or Cable
  1. After long-term use, the charger (AC adapter) may fail to provide the required voltage or the internal wiring might be damaged, even if the indicator light is on.
Damaged Charging Port (DC Jack)
3 The DC input jack where you plug in the charger may have become loose, oxidized, or broken internally due to frequent use, resulting in a poor connection.
4 Mother Board Component Failure
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
kyla буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За все время: 144
