Гарнитура смешанной реальности Meta Quest 3S была выпущена 15 октября 2024 года и является более компактной и бюджетной версией Meta Quest 3.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
It is possible for headset tracking to stop working due to sensor issues, software glitches, or connectivity issues. Ensure that the play area and lighting are properly set up, restart the device, and check the tracking cameras or sensors.
Был ли этот ответ полезен?
Счет 0
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
Счет 0
Добавьте свой ответ
Kai Bannon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 22
За последние 30 дней: 83
За всё время: 493
