Контроллер PS4 модели CUH-ZCT1. Выпущенный 15 ноября 2013 года компанией Sony Computer Entertainment, этот шестиосевой (six-axis) контроллер с литий-ионным аккумулятором 3,7 В несложен в ремонте. (ПРИМЕЧАНИЕ: руководство по разборке (teardown) НЕ ПРЕДНАЗНАЧЕНО для этой модели)
Am I using this program correctly?
Hi so I finally got the analog sticks on my controller these are the Gulikit TMR Joysticks and I dont know whats going out with the right analog stick it clicks, but doesn't register and it looks like it drifts even though they supposed to be new. I tried in BF6 and I don't notice it since I have my dead zone set to 0. Can too much or little solder cause that malfunction?
Это хороший вопрос?
Счет 0
5 Комментариев
Hi!
Can you set us pictures regarding the solder work?
Adding images to an existing question
Thanks!
из
Hi, I uploaded the photos it starts from the top going clockwise
из
Hi!
Thanks for the pictures! The pads do look damaged in the 2nd and 3rd photos. Can you remove the solder there and sent a photo again? Is that possible? Thanks!
из
I will do it as soon as I can
из
Hi, I uploaded the removed solder from the 2nd photo I did noticed the exposed copper
из
Добавить комментарий
1 ответ
Выбранное решение
Hi!
It does look like that the pads are damaged, causing this issue.
I’m afraid you need to repair the pads first.
Here is some explanation: https://youtu.be/dtZl7cLYc40?is=0ieMGMQp...
Please let me know how that goes!
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thank you I'll just a new MB and analog sticks it always something with this and its getting tiresome
из
I understand yes, I would swap it out for a new motherboard as well. Please let us know how that goes! Thanks!
из
Добавьте свой ответ
Christopher D буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 114
