Седьмое поколение плеера Apple iPod Touch, выпущенное в мае 2019 года. Данная модель оснащена накопителем объемом до 256 ГБ и процессором A10. Номер модели A2178.
Can't remove the front display!
It seems impossible to remove the front display! I used the iOpener repeatedly, a heat gun, all to no avail. I bought a new display and all the tools to replace it, but I can't get started. The adhesive just doesn't want to budge! Help!
Это хороший вопрос?
Счет 1
2 Комментариев:
OK I got it open now. It took 3-4 days of working t it. Hint to others: The display started to separate slightly on the side, at about 3/4 " above the bottom. I was able to get a razor blade between the display and the frame and slid it down to the bottom, then pulling it across the borttom cutting the adhesive. Now it is on to the rest of the work! DBS
из
Добавить комментарий
1 ответ
If the front display won't come off, don't force it. Double-check that all screws and ribbon cable connectors have been removed or disconnected. The display may still be held by adhesive clips—apply gentle heat around the edges and use a plastic opening tool to carefully separate it. Forcing it can crack the screen or damage the frame.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
David Swanson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 185
