Clean Water Tank Empty ... but it's NOT
We've had our Narwal Freo Z10 Ultra for about 6 months now. Love this thing! However, we seem to be having a recurring issue with the base station clean water tank. After filling the clean water tank and starting up, the narwal becomes angry from time to time and will say "fill clean water"... even though the tank is full and properly installed. My wife has found a temporary fix: using a baby medicine syringe to inject water into the base station clean water tank connection point. Doing this 3 or 4 times seems to clear up the issue... but a few days later same fault occurs. Anyone know of a root cause or complete fix?
Some things I have tried:
Cleaned both waste water and clean water tank thoroughly
Small pipe cleaner run through of all water lines to verify no obstructions
Thorough cleaning and maintenance of vacuum robot
This close to tearing the base station apart and doing a thorough cleaning.... when the wife isn't looking🫣
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Did you end up ever taking the base station apart? I’m trying to take the rear panel off, but something is holding it in on the left side. Do you know how to take it off. As an answer to your question sounds like it could be a water pump issue.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Attempted to pull base station apart, you have to remove the bottom panel to access the back. The plumbing inside is to tight to fully disassemble unfortunately. I will most likely review my warranty and contact supplier for support or replacement. The base station no longer registers a full clean water tank no matter what we do
из Поделиться
Resolution! Success! Water pump issue indeed! Call tech support and luckily they are aware of the issue already. 1 year warranty covered repair and shipping cost. Base station returned with water pump repair!
из Поделиться
Добавьте свой ответ
Nicholas B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 30
За последние 30 дней: 115
За все время: 843
