Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433вопросов Показать все
After changing HDD, CPU fan goes to 3500 rpm on power-on
Hi,
I just removed my old HDD, just to install an SDD in the HDD slot, and an HDD (1TB SATA on SATA-to-IDE-cart) in my Optical Slot.
Everything seems to have gone smoothly, except... For seemingly no reason, my CPU fan goes to 3500 (CPU at 30-60°C), and my HDD fan to 1300 (HDD at 50°C). I think, at least the CPU fan shouldn't do so...
I already tried resetting the SMC, and reopened it to look if I maybe removed or forgot to reattach a temperature sensor, but both did not bring any solution at all.
Any Ideas?
Thank you!
Это хороший вопрос?
Оценка 4
Добавить комментарий
9 Ответов
Выбранное решение
Make sure you reconnect the heat sensor on the hdd - that could cause runaway fans. The other possibility is that those drives actually are overheating your machine. You could run a 3rd party fan app. to monitor internal temperature and see if it's really getting that warm in there.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Actually, I forgot the first time. It really makes the HDD fan run errant. But I'm not sure about my CPU fan, this should behave normally, I suppose. Anyhow, currently all heat sensors are back in place, and CPU fan is still running full speed for no reason.
In the meantime, I triple checked if I had any connection errors, or forgotten any fans - so, unless there's a magic dwarf in my iMac unplugging the temperature sensor every time I do not look, I still don't have any clue...
Monitoring with iStat Pro btw.
из
Also check the LCD sensor wires. This was the cause of my run away full-speed left-fan. I damaged the wires reinstalling the LCD's bezel bottom left-middle long screw. In my case a little electrical tape fixed the cut wire insulation on the LCS sensor cable.
из
Ed Sutton,many thanks for your reaction.I checked the wires,and there was a little damage.Your commend solved my high speed rotating fan problem.
из
Наиболее полезный ответ
Download SSD FanController, open it and click on Manual. Put the numbers around 1500. That's it. The link is http://exirion.net/ssdfanctrl/. You may configure its preferences as to S.M.A.R.T. You'll find out when you download and install it.
If your issue is resolved, please come back and mark the answer as Accepted.
Оценка 5
6 Комментариев:
I'd rather not manually throttle my fans, but have the issue solved by the root...
из
This is the fix!
из
A Q - Sadly, fan control software is not a very good long term fix. Over time you'll kill your system. It's best in this case to put back the stuck on sensor. Following this guide: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement. Review Step 20.
из
thank you very much!!
из
this works for my iMac mid 2011 12.5inch
из
Показать 1 больше комментариев
FIXED THE ISSUE.... This took a little time, but it was a simple fix. The LCD sensor that you have to disconnect from before removing the LCD was the issue. After receiving HIGH CPU fan speeds, I began looking at possible issues. First, I had Temperature Monitor Installed. I had all my sensors including the ambient air sensor reading. After I upgraded my HD to a SSD I started getting HIGH CPU fan speeds, but the HD and DVD fan speeds were fine. I looked at my Temperature Monitor and I noticed i had several Temperature Monitors not reading including the ambient Air Temperature (bare with me, these are steps to troubleshoot). After reseting the SMC and PRAM, still nothing. I shut down and disassembled my IMAC again. This time after i removed the LCD, I looked at the LCD cable that you must disconnect when removing the LCD and BAM, I saw the issue. The wires that connect to the Motherboard from the LCD Sensor, inherently like to lay across the screw hole the Bezel attaches to. I have a couple of pinched marked that exposed the wires and when I tighten the bezel down, it shorted the wires and caused the issue. I cut small pieces of electrical tape and covered the bare spots. When I reassembled the IMAC, i mad sure that all my BEZEL screw holes were completely clear of any wires. Once back together, I plugged in the IMAC, waited 5 Seconds and turned it on. All is well. I feel this a majority of everyones issues when they take apart their IMACS and put them back together. Hope this helps.
Оценка 4
3 Комментариев:
Good catch! Pinching wires is never good.
из
Had the same issue and didn't want a bandaid. Thanks for the post!
из
+1 Same issue. I should have realized when I noticed the left-middle-bottom screw was harder to turn than the other screws. I took apart a 2nd time and could see bent wires and shiny metal showing on 2 of the 4 wires. Black taped each individually. Pushed them well clear of the screw hole. My Early 2008 iMac is now silent with a 250GB SSD and a 1TB SAT installed in a PATA-to-SATA CD caddy. All is good. Nothing destroyed, no soldering was required in my case.
из
HDD Fan Control: http://www.hddfancontrol.com
It's designed specifically for this problem.
And, instead of the terrible answer above (which sticks the fans at 1500 regardless how warm the machine is), HDD Fan Control uses the SMART sensors to ramp up the fans when needed.
I really don't understand why this program is never mentioned when someone brings up the fan problem when you change a hard drive in an iMac... but there you go.
Оценка 2
2 Комментариев:
Rob - The correct answer here is to correct what failed, not band-aid it with something you shouldn't need. BTW Fan Control is not foolproof, as not all SMART drives have temp sensors and the spec is not clear on how it should be read. In fact, that is the problem with the late '11 & early '12 Apple iMac models which did away with the external sensor and Apple tried using an internal sensor that met it's specs. these '11 & '12 systems do indeed need Fan Control when you replace the HD with a non-conforming hard drive. Newer versions of Seagate & Western Digital hard drives appear to have conforming sensors now as we have had reports (and I've seen my self) of newer drives not needing Fan Control from the get go.
из
One last point, Apple uses a few temp sensors in the system so it could be a different sensor was damaged in the process of servicing and/or a new problem has popped up. Without first diagnosing which sensor is going off and which fan/s are running and running correctly, your just shooting in the dark here. That is why you need to get a diagnostic tool like Temperature Gauge to read off the sensors and see what the fans are reporting as far as speed. Then you can figure out what the correct action is. And yes, I still often install Fan Control as a solution. But, I don't throw it on every system that has a thermo type of issue as the first answer.
из
Go to the Mac App Store and download 'Temperature Gauge' App to monitor your devices.
Did you remount the thermal sensor onto your SSD from the old HD you took off.?
Оценка 0
2 Комментариев:
I remounted the HD sensor to the SSD and the Optical Drive sensor to the new HD. I'd rather had it vice versa, but the cables have just the right length to fit as intended by apple...
So far, nothing I've done had any part heat over 50°C, so no cause for any fan to run at full speed.
из
Just to be clear here: You need to put the new HD on the original HD SATA connector and place the original HD sensor on it. The reason here is the first SATA interface temp sensor is calibrated for a hotter HD not a cooler SSD. If you reversed the expected devices you will need to splice the HD sensor cable with an extension to get it onto the HD or remount the HD back to the expected SATA connection. In older iMac's the optical drive I/O is PATA which I think swayed you into thinking you have to switch the devices around.
из
Same thing here. All fans are now continually going crazy. Everything is connected fine. I don't get it. An SMC reset doesn't work. PRAM doesn't help. Makes no sense for all the fans to be going nuts. I wonder if it is related to the LCD temp sensor. I wonder if that could be making the fans ALL continually run.
Оценка 0
1 Комментарий:
Chris - Get the Temperature Gauge App and check that out. It's possible you have problem thats appears to be a CPU or HD problem.
из
As I will have access to the AppleCare Help Desk Tools soon, I'll run a complete check and will keep you updated on this issue. Thanks for your suggestions up to now!
Оценка 0
Anyone figure out what is causing the CPU fan to run a full speed?
Оценка 0
1 Комментарий:
Yes! the issue is the lack of a firm standard on how the thermo sensors inside the HD's are to be accessed. The SMART standard was not clear so when Apple decided to use the internal sensors in the newer drives (not all HD's have this sensor) they needed to custom fit a special cable harness to each vendors HD they were using. So when we go into these systems to replace the HD you either needed to replace the HD with the same vendors drive your given system has or you needed to replace the harness with the correct one for the drive you were installing. Also remember in some cases the HD being used didn't have a internal sensor which also created more of a mess. The good news here is the current crop of HD's all have an internal sensor now and many are now using the same pins and sensor.
из
Hi, Charlie, my graphic card died on my iMac 27 late 2009, I went to apple partner service here in Slovakia, and they give me back with CPU on max and sensor showing 0 rpm, another sensors like hdd and odd are okay, I think that service man some way broke my cpu sensor or You think that problem will be like on Your iMac with LCD? Thanks for answer
Оценка 0
2 Комментариев:
torsial - What fan/temp monitoring software are you using? Temperature Monitor is a good one for the older models. I like this one Temperature Gauge Pro while it will cost you some cash it offer more information and functions.
из
As Charlie encountered a pinched wire can be the cause. I would go back to the servicer and have them address this as warranty for your original repair (that is if you still have your paperwork and the time frame is within the last week or two).
из
Добавьте свой ответ
Christian Hofmann будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 30,225
