Руководства по ремонту и диагностике неисправностей кондиционеров для дома, офиса и автомобиля.
Won't turn on
I have an older Danby, which I keep unplugged when not in use. When I plug it in, it beeps and the display shows for a second, then disappears. The power button doesn't turn it on. Unplugging and replugging gives the same result, a beep and a quick display of the last temp I had it set on, then it goes off again. Power button won't turn it back on. I've already tried the test and reset buttons on the power cord, which appear to be functioning properly.
Это хороший вопрос?
Счет 0
2 Комментариев:
@trinklingcreek what is the exact model number for your AC?
из Поделиться
DPA120E1BDB. I've already checked the owner's manual. There is nothing about maintenance or troubleshooting.
из Поделиться
Добавить комментарий
1 ответ
Hello, it looks like the motherboard is shutting down for some reason, since you're unplugging it each time you want to turn it off, maybe you're preventing the AC from starting a proper shutdown sequence, perhaps the fan has to keep turning for around 30s to prevent moisture or condensation to form on the motherboard or some electronic part.
I think a good start is to reach the board and clean it if possible or jiggle it, just don't forget to unplug the cord and becarful of the capacitors they still can hold charge.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Trinkling Creek буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За все время: 83
