Руководства по ремонту, инструкции и помощь по устранению неполадок для Xiaomi Redmi Note 13 4G. Получите все необходимое для самостоятельного ремонта Вашего Xiaomi Redmi Note 13 4G.
My Redmi Note 13 won't turn on.
Xiaomi Redmi Note 13 4G"> My Xiaomi Redmi Note 13 4G won't turn on. I have tried forced restarts (holding power and volume buttons), charging for over 30 minutes with the original charger, and trying to enter Recovery Mode, but the phone remains completely unresponsive with no screen activity, LED, or vibration. What hardware component or further troubleshooting should I check?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If it’s completely dead with no vibration, charging symbol, or LED, I’d start looking at the battery and charging/power circuit rather than software.
Try a different known-good USB-C cable/charger and check the port for damage or debris. If still completely dead, the next step is measuring the battery voltage and checking whether power is reaching the board.
At that point, a failed battery, charging port, fuse, or power-management IC are all possibilities.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
It didn't work, he still doesn't call.
из
Добавьте свой ответ
Luiz Otavio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 12
За всё время: 12
