Huawei Mate 10 Battery Replacement
Выберете то, что вам нужно
  1. Huawei Mate 10 Battery Replacement, Remove the back cover: шаг 1, изображение 1 из 3 Huawei Mate 10 Battery Replacement, Remove the back cover: шаг 1, изображение 2 из 3 Huawei Mate 10 Battery Replacement, Remove the back cover: шаг 1, изображение 3 из 3
    • Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone.
    • While you wait, note the location of the adhesive holding the back cover in place.
  2. Huawei Mate 10 Battery Replacement: шаг 2, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 2, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 2, изображение 3 из 3
    • Place a suction cup near the bottom edge of the back cover, on the right side (opposite the speaker grille) of the USB-C charging port, above the microphone hole.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. If all else fails, you can superglue the suction cup to the back cover.
    • Pull on the suction cup with strong, steady force to create a gap.
    • Due to the adhesive's strength, this is very difficult and may take multiple attempts. If you can't create a gap, re-apply heat and try again.
    • Insert the point of an opening pick into the gap.
  3. Huawei Mate 10 Battery Replacement: шаг 3, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 3, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 3, изображение 3 из 3
    • Slide the pick along the bottom edge and around the bottom-left corner, slicing through the adhesive.
    • If the adhesive feels tacky and difficult to slice, re-apply heat to the edge and try again.
    • Leave an opening pick in the seam to prevent the edge from re-sealing.
  4. Huawei Mate 10 Battery Replacement: шаг 4, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 4, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 4, изображение 3 из 3
    • Apply a heated iOpener to the left edge of the phone.
    • Use an opening pick to slice through the adhesive on the left edge of the phone.
    • The adhesive is very thick in some areas. Sustained exposure to heat will help weaken the stubborn adhesive. Take your time, and apply heat liberally.
  5. Huawei Mate 10 Battery Replacement: шаг 5, изображение 1 из 2 Huawei Mate 10 Battery Replacement: шаг 5, изображение 2 из 2
    • Continue heating and slicing through the remaining edges, leaving opening picks in the seams to prevent the adhesive from re-sealing.
  6. Huawei Mate 10 Battery Replacement: шаг 6, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 6, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 6, изображение 3 из 3
    • After you cut through the adhesive around the entire perimeter of the back cover, begin to lift it away from the phone.
    • Use an opening pick to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  7. Huawei Mate 10 Battery Replacement, Prep the phone for a new back cover: шаг 7, изображение 1 из 2 Huawei Mate 10 Battery Replacement, Prep the phone for a new back cover: шаг 7, изображение 2 из 2
    • Before you install a replacement back cover, be sure to remove all traces of perimeter adhesive from the phone frame.
    • If you are re-using the back cover, carefully remove all traces of adhesive from the back cover.
    • The glass back cover is fragile and prone to cracking. Don't apply uneven pressure to the back cover as you clean.
    • You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
  8. Huawei Mate 10 Battery Replacement: шаг 8, изображение 1 из 2 Huawei Mate 10 Battery Replacement: шаг 8, изображение 2 из 2
    • If your replacement back cover did not come with a flash diffuser or camera bezel, you will need to transfer them from your old cover to the new one.
    • Apply a heated iOpener directly over the bezels for a minute.
    • Use an opening pick to slice around the flash diffuser to loosen the adhesive.
    • The flash diffuser is made of plastic and cracks easily. Be sure to slice around the flash completely before you pry it off.
    • Use an opening tool to pry up and remove the camera bezel.
    • Transfer the parts to your replacement cover.
  9. Huawei Mate 10 Battery Replacement, Remove the plastic bracket: шаг 9, изображение 1 из 2 Huawei Mate 10 Battery Replacement, Remove the plastic bracket: шаг 9, изображение 2 из 2
    • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
    • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
    • One screw lies beneath a white sticker. Remove the sticker.
    • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
  10. Huawei Mate 10 Battery Replacement: шаг 10, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 10, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 10, изображение 3 из 3
    • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
    • Pull the plastic bracket away from the top edge of the phone.
    • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
    • Remove the plastic bracket along with the heat dissipation layer.
  11. Huawei Mate 10 Battery Replacement, Disconnect the battery: шаг 11, изображение 1 из 2 Huawei Mate 10 Battery Replacement, Disconnect the battery: шаг 11, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  12. Huawei Mate 10 Battery Replacement, Disconnect the interconnect cable: шаг 12, изображение 1 из 2 Huawei Mate 10 Battery Replacement, Disconnect the interconnect cable: шаг 12, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Huawei Mate 10 Battery Replacement: шаг 13, изображение 1 из 2 Huawei Mate 10 Battery Replacement: шаг 13, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
  14. Huawei Mate 10 Battery Replacement, Disconnect the button connector: шаг 14, изображение 1 из 1
    • Use the point of a spudger to pry up and disconnect the button connector from its motherboard socket.
  15. Huawei Mate 10 Battery Replacement, Remove the glued-in battery: шаг 15, изображение 1 из 2 Huawei Mate 10 Battery Replacement, Remove the glued-in battery: шаг 15, изображение 2 из 2
    • The battery is held in place by very strong adhesive.
    • Apply a heated iOpener to the left side of the phone screen for a minute.
    • While you wait, note where the U-shaped adhesive resides on the phone frame.
  16. Huawei Mate 10 Battery Replacement: шаг 16, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 16, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 16, изображение 3 из 3
    • Insert an opening pick in the notch on the phone's right edge.
    • Slowly but firmly push the pick underneath the battery, to loosen it from the frame.
    • If you are having trouble getting the pick under the battery, you can apply some high concentration isopropyl alcohol to the seam. Give the alcohol a minute to penetrate and soften the adhesive.
  17. Huawei Mate 10 Battery Replacement: шаг 17, изображение 1 из 2 Huawei Mate 10 Battery Replacement: шаг 17, изображение 2 из 2
    • Slowly insert an opening pick in the top edge of the battery, towards the right edge.
    • Twist slightly to help loosen the battery.
  18. Huawei Mate 10 Battery Replacement: шаг 18, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 18, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 18, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Insert a plastic card under the battery's right edge.
    • Push the card inwards to loosen the battery from the frame.
    • If you're having a hard time loosening the battery, you can apply more isopropyl alcohol, or try to soften the adhesive with more heat.
    • Try not to deform the battery as you pry.
  19. Huawei Mate 10 Battery Replacement: шаг 19, изображение 1 из 3 Huawei Mate 10 Battery Replacement: шаг 19, изображение 2 из 3 Huawei Mate 10 Battery Replacement: шаг 19, изображение 3 из 3
    • Once the battery is sufficiently loosened from the frame, slowly lift it out.
    • Remove the battery.
    • To install a replacement battery:
    • Apply new adhesive to the phone frame.
    • Gently lay the battery pack in the phone.
    • Temporarily reconnect the battery to the motherboard to ensure that the battery is properly aligned.
    • Once the battery is aligned, press it firmly in place with your fingers. Disconnect the battery from the motherboard, and resume re-assembly.
    • For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
6 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
253 248 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 141 руководств
6 Комментариев
Excellent Guide!!! Very clear and detailed.. I replaced the battery on my Mate 10 in just 30 min without any problems.. Thank you!!!
Fernando Sancez - Ответить
Quest è il Mate 10 PRO, Aggiungete Pro!
Ed Evitiamo Confusione.
Just Step - Ответить
Buongiorno! Infatti questa guida è stata scritta per lo Huawei Mate 10. Se guardi bene questa foto, vedi il numero di modello ALP-L29 che corrisponde al Mate 10. Invece, siccome i due telefoni son molto simili, puoi seguire le stesse istruzioni per ripararli. Ma non devi! Ci sono qui le guide per il Mate 10 Pro.
Claire Miesch -
Muchas gracias, excelente información me ayudó muchísimo.
Rafa Sanchez - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 25
За последние 30 дней: 129
За всё время: 11,285
