AEE Mach 1 Drone Propeller Replacement
    1. AEE Mach 1 Drone Propeller Replacement, Propeller: шаг 1, изображение 1 из 1
      • Make sure your drone is powered off and the battery is removed from the drone.
      • Identify the defective propeller on your drone.
      • Each propeller is marked as either 'A' or 'B'. Make sure the new propeller matches the old one.
      Спросите у FixBot
      Добавить комментарий
    2. AEE Mach 1 Drone Propeller Replacement: шаг 2, изображение 1 из 1
      • In the center of each propeller, near the base, there are two arrows.
      • The symbol circled in red indicates the direction to "unlock" the propeller from the drone; this symbol indicates the direction to unscrew the rotor off of its mount.
      • The symbol circled in orange indicates the direction to "lock" the propeller onto the drone; this symbol indicates the direction to screw the rotor back onto the mount.
      Спросите у FixBot
    3. AEE Mach 1 Drone Propeller Replacement: шаг 3, изображение 1 из 1
      • While keeping the motor under the propeller still, rotate the propeller in the direction shown to "unlock" the propeller.
      • The direction to unlock the propeller will depend on the letter labeled on the propeller.
      Спросите у FixBot
    4. AEE Mach 1 Drone Propeller Replacement: шаг 4, изображение 1 из 1
      • Once you unscrew the propeller from the drone you will then be able to inspect the area for any additional damages.
      Спросите у FixBot
    5. AEE Mach 1 Drone Propeller Replacement: шаг 5, изображение 1 из 1
      • Replace the defective propeller with one of the replacements that come with your drone, or you can attempt to fix the defective propeller.
      • To replace a propeller, simply place the rotor on the screw, and screw the propeller by rotating the propeller in the direction indicated by the arrow next to the “Lock” symbol.
      • The direction to lock the propeller on the drone will depend on the letter the propeller is labeled.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Patrick Lewis
Участник с: 09/04/19
394 Репутация
Автор 2 руководств
Команда
University of Alabama, Team S1-G4, Bedsole Fall 2019 Участник University of Alabama, Team S1-G4, Bedsole Fall 2019
UA-BEDSOLE-F19S1G4
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 33
За всё время: 1,113
