ASUS D550MA-DS01 DVD Drive Replacement
Выберете то, что вам нужно
  1. ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: шаг 1, изображение 1 из 2 ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: шаг 1, изображение 2 из 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
    Спросите у FixBot
    Добавить комментарий
  2. ASUS D550MA-DS01 DVD Drive Replacement: шаг 2, изображение 1 из 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
    Спросите у FixBot
  3. ASUS D550MA-DS01 DVD Drive Replacement: шаг 3, изображение 1 из 2 ASUS D550MA-DS01 DVD Drive Replacement: шаг 3, изображение 2 из 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    Спросите у FixBot
  4. ASUS D550MA-DS01 DVD Drive Replacement: шаг 4, изображение 1 из 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    Спросите у FixBot
  5. ASUS D550MA-DS01 DVD Drive Replacement: шаг 5, изображение 1 из 1
    • Remove the fully disconnected keyboard module from the laptop.
    Спросите у FixBot
  6. ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: шаг 6, изображение 1 из 2 ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: шаг 6, изображение 2 из 2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
    Спросите у FixBot
  7. ASUS D550MA-DS01 DVD Drive Replacement: шаг 7, изображение 1 из 1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
    Спросите у FixBot
Заключение
Richard Johnson
Участник с: 09/16/15
707 Репутация
Автор 5 руководств
Команда
IUPUI, Team 1-2, Baechle Fall 2015 Участник IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 членов
Автор 8 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 853
