ASUS Portable AiO PT2001 RAM Replacement
Выберете то, что вам нужно
    1. ASUS Portable AiO PT2001 RAM Replacement, Back Panel: шаг 1, изображение 1 из 3 ASUS Portable AiO PT2001 RAM Replacement, Back Panel: шаг 1, изображение 2 из 3 ASUS Portable AiO PT2001 RAM Replacement, Back Panel: шаг 1, изображение 3 из 3
      • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
      • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
      • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
      • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
      Спросите у FixBot
      Добавить комментарий
    2. ASUS Portable AiO PT2001 RAM Replacement: шаг 2, изображение 1 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 2, изображение 2 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 2, изображение 3 из 3
      • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
      • We recommend that you start prying the panel where the scuff guard was removed.
      • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
      • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
      Спросите у FixBot
    3. ASUS Portable AiO PT2001 RAM Replacement: шаг 3, изображение 1 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 3, изображение 2 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 3, изображение 3 из 3
      • Disconnect the three cables connecting the back panel ports to the motherboard.
      • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
      • Gently wiggle the third connector out of its socket.
      Спросите у FixBot
    1. ASUS Portable AiO PT2001 RAM Replacement, RAM: шаг 4, изображение 1 из 2 ASUS Portable AiO PT2001 RAM Replacement, RAM: шаг 4, изображение 2 из 2
      • Peel off the tape attaching the metal enclosure to the heat sink.
      • Lift the metal enclosure off of the motherboard.
      Спросите у FixBot
    2. ASUS Portable AiO PT2001 RAM Replacement: шаг 5, изображение 1 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 5, изображение 2 из 3 ASUS Portable AiO PT2001 RAM Replacement: шаг 5, изображение 3 из 3
      • Pull the jaws of the white plastic frame apart. This will pop the front of the RAM up.
      • Gently lift the front edge of the RAM.
      • Pull the RAM out and up.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Elliot Kane
Участник с: 04/17/18
381 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G5, Livingston Spring 2018 Участник Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 членов
Автор 72 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 32
За всё время: 1,760
