Введение
This is how to replace your broken or damaged Hard Drive on your Asus UX50V-RX05 laptop.
Выберете то, что вам нужно
Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
Remove the cable after pushing out the two black clips.
Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
Remove the cable after pushing out both black clips.
Remove the keyboard.
Remove the thirteen 5 mm J0 screws from the back of the laptop.
With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
Using the screwdriver with the JO bit, remove the two Phillips 4 mm head size 5 mm long screws from the Hard Drive.
Flip the Hard Drive over without lifting.
Using your fingers, unplug the cord by pulling it away from the hard drive.
