Введение
Need to access the internals of your ASUS VG248? Here's a guide that shows how to remove the frame and open the display.
Выберете то, что вам нужно
Four rubbery covers hide four screws in the rear of the monitor.
Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
Lay the cloth over one of the long edges of the display.
Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
Repeat the procedure around the display, lifting up the center of the next side.
Now that you've freed the centers of the four sides, it's time to move on to the corners.
Инструмент, используемый на этом этапе:Jimmy$7.95
Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
If any corners are particularly stubborn, repeat the previous step on the difficult corner.
With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
23 человек успешно провели ремонт по этому руководству.
11 Комментарии к руководству
Do you know of any place that sell the replacement lcd screen?
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
You could yes, but be very careful NOT to introduce dust into the panel!
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
