Введение
The fan in your ASUS X502CA keeps components cool while the laptop's running. If your laptop's performance has been dropping, or it feels unusually hot, odds are that the fan is either dirty or damaged.
Before replacement, make sure your fan doesn't just need a good cleaning with an ESD-safe brush and compressed air; gunky blades can't move air efficiently, and often clog with regular use, especially if you have furry pets that like to shed.
If your fan is damaged and not just dirty, it's likely time to replace it altogether.
It is possible that your fan has stopped working due to physical or electrical damage. A replacement fan will need to be purchased before beginning. After purchasing a new fan follow these steps to replace the broken fan of your ASUS X502CA.
Discharge your battery and unplug your laptop before beginning.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove:
Eight 9 mm screws.
Four 5 mm screws.
Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
Инструмент, используемый на этом этапе:Tweezers$4.99
Lift the keyboard cover carefully.
Disconnect the keyboard and touch-pad ribbons using tweezers.
Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
6 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Great tutorial.
Thanks Bro! :)
