Введение
The fan helps get rid of the excess heat in the laptop. A damaged fan can cause overheating and poor performance. This guide explains how to replace it.
Выберете то, что вам нужно
Place the laptop on a flat surface with the bottom side facing upwards.
Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
Using both hands, slide the back panel away from the laptop horizontally.
Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
Locate the three ribbon connectors.
Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
Disconnect the optical drive from the motherboard by sliding it to the right.
Инструмент, используемый на этом этапе:Tweezers$4.99
Flip the motherboard to show the underside.
Locate the square fan connection attached to the motherboard.
Disconnect it using the tweezers (blunt).
Еще один человек закончил это руководство.
1 Комментарий к руководству
my mouse of laptop not working pls guide to repaire
