Введение
Use this guide to replace a screen that is scratched, cracked, or broken.
Выберете то, что вам нужно
Using needle nose pliers, remove the washers from the four corner selector knobs.
Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
Carefully flip the device to the front making sure you secure the face plate and the chassis together.
Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
Using a Phillips #2 screwdriver, remove the one 9.8mm screw holding down the ground wire.
Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
To reassemble the display, follow these instructions in reverse order.
3 человек успешно провели ремонт по этому руководству.
