AlphaSmart Pro Individual Key Replacement
Выберете то, что вам нужно
  1. AlphaSmart Pro Individual Key Replacement, Removing a Key: шаг 1, изображение 1 из 2 AlphaSmart Pro Individual Key Replacement, Removing a Key: шаг 1, изображение 2 из 2
    • Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up.
    • You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
    Спросите у FixBot
    Добавить комментарий
  2. AlphaSmart Pro Individual Key Replacement, The Spacebar Spring: шаг 2, изображение 1 из 1
    • If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
    • Remove the spring and place it to the side so it doesn't get lost.
    • It does not matter which of the two circular spots the spring is on.
    • There is only one spring per spacebar. If the spring is missing, don't worry — the spacebar will work fine without it — but it will work better when the spring is attached.
    Спросите у FixBot
  3. AlphaSmart Pro Individual Key Replacement, Removing Other Keys: шаг 3, изображение 1 из 1
    • If you wish to remove another key besides the spacebar, the same methods of removal apply.
    • You should hear a "popping" or "snapping" sound when the key has been removed.
    • Unlike the spacebar key, all the other keys do not have a spring.
    Спросите у FixBot
  4. AlphaSmart Pro Individual Key Replacement, Replacement: шаг 4, изображение 1 из 2 AlphaSmart Pro Individual Key Replacement, Replacement: шаг 4, изображение 2 из 2
    • To replace the key(s), simply align the center cylindrical post(s) with the center holes.
    • Use your index finger to press down on the middle of the key. You should hear it "click" into place.
    Спросите у FixBot
Заключение
Katy Beth Culp
Участник с: 10/13/14
1 Репутация
Автор 2 руководств
Команда
Clemson, Team 1-1, Benson Fall 2014 Участник Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 членов
Автор 16 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 46
За всё время: 1,993
