Введение
Is your Altec Lansing BoomJacket having charging issues or will not charge at all? Replacing the battery may help.
Выберете то, что вам нужно
Using your hands, remove the pegs (4+4) from the front and back of the speaker.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
Pull the case apart and you will be able to see all the components inside the speaker.
The battery will be sitting right behind the speakers when the case is open.
5 человек успешно провели ремонт по этому руководству.
6 Комментарии к руководству
Where can you buy a replacement battery?
Where can you buy the battery please?
Where can I find ghe batteries? What type of battery ?
where ca i buy a replacement battery
This tutorial is incomplete.
