Alternative Opening Procedure
Выберете то, что вам нужно
  1. Alternative Opening Procedure, Alternative Opening Procedure: шаг 1, изображение 1 из 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
    Спросите у FixBot
    Добавить комментарий
  2. Alternative Opening Procedure: шаг 2, изображение 1 из 2 Alternative Opening Procedure: шаг 2, изображение 2 из 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
    Спросите у FixBot
  3. Alternative Opening Procedure: шаг 3, изображение 1 из 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
    Спросите у FixBot
Заключение
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 человек успешно провели ремонт по этому руководству.
Donald Todd
Участник с: 09/22/10
528 Репутация
1 руководство автора
2 Комментарии к руководству
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Ответить Поделиться
There's a third technique I intuited when I looked at the other method and decided "...no. That's too rough."
The key is using a suitably thin prying tool but only to gently press on the clips, while applying pressure on the back I/O shield with your other hand so they'll pop out and stay out the moment you've applied enough pressure on them... sort of like how, in lock-picking, you have a tensioning bar to keep the pins set as you work on them one-by-one.
You start with the clip nearest one side of the back and work your way around.
Maybe it's just me, but it feels even less risky than sticking pins in, given the technique I assume is required to avoid accidentally gouging each pin into the plastic.
That said, I WILL admit that I'm not sure what "suitably thin prying tool" to recommend. Mine is some generic eBay/Aliexpress thing from 10+ years ago that doesn't seem to be made in that exact form anymore and the iFixit Pro Tech Toolkit is still on my Christmas wishlist, so I don't know how the iFixit Jimmy compares.
ssokolow - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 18
За последние 30 дней: 63
За всё время: 15,999
